Ga door naar hoofdinhoud
Samsung Galaxy S7 Power/Volume Button Flex Replacement
Wat je nodig hebt
Video-instructies
Conclusie
10 andere personen hebben deze handleiding voltooid.
Witrigs
69.454 Reputatie
378 handleidingen geschreven
2 opmerkingen
Is there something on the motherboard that could be damaged that would stop the volume buttons from working? Got a customer's phone where their volume buttons don't work post screen replacement. Just tried replacing the volume button flex but no luck. They applied a software update but haven't tried a factory reset yet.
FixNcell Phone Repair - Antwoord
First off, Thank you for the video ! Very helpful and thorough.
2 comments to make:
1) be aware that the back cover is glass, so therefore is extremely fragile when prying open/removing. I cracked mine, so need to replace that now. So, some additional tips (maybe additional/constant heat to loosen the glue ??) or caution is necessary for anyone not aware.
2) IF your only replacing the Volume Buttons, for me, I only removed the screws , the Antenna, and NFC module. Then I could unplug the volume control and replace. Without removing anything else as shown. Of course if your doing the power button as well, then you would have to continue further.
Robert Gibbon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 60
Altijd: 29,106
