Ga door naar hoofdinhoud
Samsung Galaxy S7 Active Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: stap 1, afbeelding 1 van 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: stap 2, afbeelding 1 van 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy S7 Active Screen Replacement: stap 3, afbeelding 2 van 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: stap 4, afbeelding 1 van 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Samsung Galaxy S7 Active Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Samsung Galaxy S7 Active Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy S7 Active Screen Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy S7 Active Screen Replacement: stap 6, afbeelding 3 van 3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Erick Vazquez
180 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G1, Livingston Spring 2018 Lid van Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Leden
15 handleidingen geschreven
3 opmerkingen
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Antwoord
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Antwoord
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 9,050
