Ga door naar hoofdinhoud
Samsung Galaxy S7 Active Rear Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy S7 Active Rear Camera Replacement, Samsung Galaxy S7 Active Disassembly: stap 1, afbeelding 1 van 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Rear Camera Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy S7 Active Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Rear Camera Replacement, Battery: stap 5, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Rear Camera Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Rear Camera Replacement: stap 8, afbeelding 1 van 1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Rear Camera Replacement: stap 9, afbeelding 1 van 1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Rear Camera Replacement: stap 10, afbeelding 1 van 1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Rear Camera Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy S7 Active Rear Camera Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy S7 Active Rear Camera Replacement: stap 11, afbeelding 3 van 3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Rear Camera Replacement: stap 12, afbeelding 1 van 2 Samsung Galaxy S7 Active Rear Camera Replacement: stap 12, afbeelding 2 van 2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
  13. Samsung Galaxy S7 Active Rear Camera Replacement, Rear Camera: stap 13, afbeelding 1 van 1
    Koop
    • Use tweezers to disconnect the front camera from the battery.
    • The connector should unsnap similar to a lego piece.
Conclusie
Joe De Leone
310 Reputatie
3 handleidingen geschreven
Cal Poly, Team S18-G1, Livingston Spring 2018 Lid van Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,808
