Ga door naar hoofdinhoud
Samsung Galaxy S7 Active Disassembly
Wat je nodig hebt
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: stap 1, afbeelding 1 van 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: stap 2, afbeelding 1 van 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: stap 3, afbeelding 1 van 2 Samsung Galaxy S7 Active Disassembly: stap 3, afbeelding 2 van 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: stap 4, afbeelding 1 van 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Chengbin Owen Kuang
207 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G1, Livingston Spring 2018 Lid van Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Leden
15 handleidingen geschreven
Één opmerking
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 4,403
