Ga door naar hoofdinhoud
Samsung Galaxy S6 SIM Card Replacement
Wat je nodig hebt
  1. Samsung Galaxy S6 SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 2 Samsung Galaxy S6 SIM Card Replacement, SIM Card: stap 1, afbeelding 2 van 2
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
    • Press to eject the SIM card tray.
    • Don't press too hard or you may damage the SIM card tray.
    It really needs to be stated at the outset that if doing this repair to replace the daughterboard, there is a high likelihood that the display will be destroyed (even if you don’t break the display, the foil backing on it will likely be destroyed rendering it unusable). The PDF version of this guide states this at the beginning, but this online version does not.
    David White - Antwoord
    Done. Thanks for the tip!
    Minor editor -
  2. Samsung Galaxy S6 SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the SIM card tray from the phone.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Evan Noronha
223.469 Reputatie
168 handleidingen geschreven
4 opmerkingen
What if the tray broke, can I order one
ciscokidyo - Antwoord
The Samsung galaxy s6 does not come with tray for the sim card. It has an internal memory chip. How do you get to the internal memory chip?
Zakia Gregory - Antwoord
I made a mistake, got the sim card mixed up with the memory chip.
I replaced the battery in my Galaxy S6, but when I put it back together it no longer recognized my Sim Card. I tried my sim card in a different Galaxy S6 which recognized the card. I am afraid I will cause further damage. Any recommendations?
Shane Shellenbarger - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 70
Altijd: 18,320
