Inleiding
Follow this guide to replace the motherboard on your Samsung Galaxy S6.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Gereedschap
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
Press to eject the SIM card tray.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
Firmly grasp the edge of the midframe assembly.
Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
Use the flat end of a spudger to disconnect the front-facing camera from its connector on the motherboard.
Remove the camera.
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
70 andere personen hebben deze handleiding voltooid.
10 Opmerkingen
where did you purchase the glass adhesive
Can motherboard from s6 edge fit into motherboard of S6?
No. The s6 edge Motherboard has different cable connections than the s6.
Where can I buy a Samsung s6 edge motherboard 32gb unlocked ? Urgent please
