Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Prereq to remove the motherboard.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Onderdelen
Geen onderdelen opgegeven.
  1. Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard. Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard. Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
    • Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
  2. Use the flat end of the spudger to disconnect the home button connector. Use the flat end of the spudger to disconnect the home button connector.
    • Use the flat end of the spudger to disconnect the home button connector.
  3. Manta schroevendraaierset
    112 bitjes voor elke reparatie.
    Upgrade Your Toolbox
  4. Use the flat end of a spudger to disconnect the display assembly cable from the motherboard. Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
    • Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
  5. Disconnect the earpiece speaker assembly cable  connector from the motherboard. Disconnect the earpiece speaker assembly cable  connector from the motherboard.
    • Disconnect the earpiece speaker assembly cable connector from the motherboard.
  6. Lift the camera-side end of the motherboard to separate it from the display frame. You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
    • Lift the camera-side end of the motherboard to separate it from the display frame.
    • You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
    • Do not fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
  7. Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard. Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
Conclusie
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
3 andere personen hebben deze handleiding voltooid.
Evan Noronha
189.748 Reputatie
178 handleidingen geschreven
iFixit Lid van iFixit
Community
116 Leden
11.204 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 798
