Ga door naar hoofdinhoud
Samsung Galaxy S5 Interior Midframe Assembly Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. Samsung Galaxy S5 Interior Midframe Assembly Replacement, Interior Midframe Assembly: stap 1, afbeelding 1 van 1
    • Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
  2. Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 2, afbeelding 1 van 1
    • Flip the phone over and remove the following screws from the battery side of the midframe:
    • Two 4.4 mm Phillips #000 screws near the USB port on the battery side of the phone
    • One 4.4 mm Phillips #000 screw
  3. Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 3, afbeelding 3 van 3
    • Gently run a plastic opening tool down along the left inner side of the interior frame to separate the three white plastic clips.
  4. Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 4, afbeelding 2 van 2
    • The midframe is composed of two halves that encase the motherboard.
    • Gently pull the long sides of the silver bezel out away from the phone to separate the two halves of the midframe.
    • It may be helpful to gently push in from the inside of the battery compartment, but be careful not to flex the interior half of the midframe, as the motherboard is mounted to it.
  5. Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 5, afbeelding 2 van 2
    • Continue on to the right side of the silver bezel, pulling away from the interior section of the midframe to separate the two halves.
  6. Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to pry any remaining corners out of the silver bezel.
  7. Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy S5 Interior Midframe Assembly Replacement: stap 7, afbeelding 2 van 2
    • Carefully remove the interior midframe/motherboard assembly from the white inner midframe.
Conclusie
Sam Goldheart
465.602 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.718 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 376
