Inleiding
Use this guide to replace a faulty front-facing camera.
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
Use a plastic opening tool to pry up the plastic midframe connector panel.
Remove the connector panel with a pair of tweezers.
Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
Remove the single 3.0 mm Phillips #00 screw securing the motherboard to the midframe.
Use the flat end of a spudger to lift the front-facing camera connector straight up off its socket on the motherboard.
Remove the front-facing camera from the motherboard with a pair of tweezers.
28 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
Good guide for everyone
i broke the LCD, it was replaced before and they putted to much adhesive, i am broke :(
thanks for sharing
