Ga door naar hoofdinhoud
Samsung Galaxy S5 Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy S5 Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy S5 Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy S5 Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy S5 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy S5 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Conclusie
83 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.777 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
10 opmerkingen
This is too complicated :(
Jaydon - Antwoord
Extremely easy
taesusman - Antwoord
I replaced the battery in my phone because it drained fast, and drained completely in any temp below 50, I put the new battery In but when I try to turn it on the farthest I get is the screen that says "Samsung galaxy s5" help?
mw - Antwoord
Do I also need to remove the sim card? Or can I just put a new battery in?
nancysapone - Antwoord
Thanks am replacing glass as well...easy to get the battery and sim out.
rob taylor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 227
Altijd: 95,415
