Ga door naar hoofdinhoud
Samsung Galaxy S5 Active Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy S5 Active Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Active Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy S5 Active Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy S5 Active Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Conclusie
To install the new battery, follow these instructions in reverse order.
11 andere personen hebben deze handleiding voltooid.
Nils David Corrales Tovar
3.228 Reputatie
7 handleidingen geschreven
USF Tampa, Team 1-5, Hickman Fall 2014 Lid van USF Tampa, Team 1-5, Hickman Fall 2014
USFT-HICKMAN-F14S1G5
3 Leden
Één opmerking
Awesome! I called around to the “WeFixYourPhone” places and they told me that battery couldn’t be replaced in a Samsung S5 Active, or they’d replace it for $40 if I bought the battery. Battery $13.50 for a 3200 mAmp one, Amazon Primed it to me. And the 45 seconds to replace it is no joke. That’s all it took. It took longer to get the Otter Box off the phone.
Lisa Swager - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 26,766
