Ga door naar hoofdinhoud
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
Wat je nodig hebt
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: stap 1, afbeelding 1 van 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 2, afbeelding 1 van 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 3, afbeelding 1 van 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: stap 4, afbeelding 1 van 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: stap 4, afbeelding 2 van 2
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: stap 5, afbeelding 1 van 1
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: stap 6, afbeelding 1 van 1
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 7, afbeelding 1 van 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 7, afbeelding 2 van 2
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 8, afbeelding 1 van 1
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 9, afbeelding 1 van 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 9, afbeelding 2 van 2
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 10, afbeelding 1 van 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 10, afbeelding 2 van 2
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 11, afbeelding 1 van 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 11, afbeelding 2 van 2
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 12, afbeelding 1 van 3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 12, afbeelding 2 van 3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 12, afbeelding 3 van 3
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 13, afbeelding 1 van 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: stap 13, afbeelding 2 van 2
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Richard
29.761 Reputatie
11 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
16.577 handleidingen geschreven
Één opmerking
Thank You so much!
Peter Handless - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 5,160
