Ga door naar hoofdinhoud
Samsung Galaxy S4 Midframe Replacement
Wat je nodig hebt
  1. Samsung Galaxy S4 Midframe Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy S4 Midframe Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Midframe Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy S4 Midframe Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy S4 Midframe Replacement: stap 2, afbeelding 3 van 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Antwoord
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Antwoord
  3. Samsung Galaxy S4 Midframe Replacement, MicroSD Card: stap 3, afbeelding 1 van 3 Samsung Galaxy S4 Midframe Replacement, MicroSD Card: stap 3, afbeelding 2 van 3 Samsung Galaxy S4 Midframe Replacement, MicroSD Card: stap 3, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Samsung Galaxy S4 Midframe Replacement, Battery: stap 4, afbeelding 1 van 3 Samsung Galaxy S4 Midframe Replacement, Battery: stap 4, afbeelding 2 van 3 Samsung Galaxy S4 Midframe Replacement, Battery: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    it worked for me
    John Donovan - Antwoord
  5. Samsung Galaxy S4 Midframe Replacement, SIM Card: stap 5, afbeelding 1 van 3 Samsung Galaxy S4 Midframe Replacement, SIM Card: stap 5, afbeelding 2 van 3 Samsung Galaxy S4 Midframe Replacement, SIM Card: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Antwoord
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Antwoord
  6. Samsung Galaxy S4 Midframe Replacement, Midframe: stap 6, afbeelding 1 van 1
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    How much it will cost to replace a midframe
    kannan - Antwoord
    How much cost will be on replace a midframe
    Hiren pedhadiya -
    I'm seeing midframes available on Ebay for around $10.
    Alex - Antwoord
    I purchased a 1.5x40mm Phillips screw driver and was able to remove all 9 40mm screws from the midframe as per the Step 6 Midframe instructions.
  7. Samsung Galaxy S4 Midframe Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy S4 Midframe Replacement: stap 7, afbeelding 2 van 2
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
    I used same tool as in the photo and i broke the display. I think you should use a very thin plastic tool, such as a credit card but even more thin and flexible.
    nicosoranno4gxo - Antwoord
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9.
    This blue Case Opening tool has a less rigid edge that is kinder to trim than the hard black Spudger shown in later steps. I was glad to have the right tool on hand at this step. Use it as a wedge and slide it along the gap.
    Tom Huber - Antwoord
  8. Samsung Galaxy S4 Midframe Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy S4 Midframe Replacement: stap 8, afbeelding 2 van 2
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Midframe Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy S4 Midframe Replacement: stap 9, afbeelding 2 van 2
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Midframe Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy S4 Midframe Replacement: stap 10, afbeelding 2 van 2
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    On my phone, there was another clip holding the white midframe to the battery compartment, in the middle of the top edge of the battery compartment, near the battery contacts. If you don't release that before removing the midframe, it is easy to break.
    josephoswald - Antwoord
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them.
  11. Samsung Galaxy S4 Midframe Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy S4 Midframe Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy S4 Midframe Replacement: stap 11, afbeelding 3 van 3
    • Remove the midframe from the display assembly.
    here i leave them a video i made doing the work
    https://www.youtube.com/watch?v=85pOvI6O...
    enjoy
    Gabriel Barrandeguy - Antwoord
    My Sprint S4 was slightly different then the one pictured above but I just completed this repair in under 10 minutes.. It would have been slightly quicker but fooling around with those little screws can be irritating if you have big hands.
    Michael Willis - Antwoord
    Just did this on my S4. Instructions were extremely helpful, but I had to remove a screw (step 10.5?) to remove the upper display assembly bracket. Other than that, flawless! Thanks!
    JackieME - Antwoord
    The 3rd image of the 11th step shows that when the midframe is removed, some parts come along with it (at the bottom part of it). What are these parts? should they be removed too and placed in the new midframe? Are they easy to remove?
    Chris - Antwoord
Conclusie
93 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.777 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
5 opmerkingen
I cracked the "front facing" bezel on my phone. I thought buying a new mid frame would replace it, but based on these pictures, it looks like it is attached to the the front glass. Is this correct? Is there any way to replace just that front facing bezel?
Marwan - Antwoord
i was wondering the same thing. Can you guys please respond.
Rival Archer -
Yes, the bezel is attached to the front glass. Replacing the glass doesnt cost too much (under 15 eur here) but theres a high chance you will break the lcd digitizer in the process. It needs some skill.
Mark Bernstein -
Hi... Is that the whole body is model GT-I9505 and How much it costs me the whole body?
Priya - Antwoord
Hi.. Is that the whole body is with mirror and how much it costs me??
Priya - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 130,028
