Ga door naar hoofdinhoud
Samsung Galaxy S4 MicroSD Card Replacement
Wat je nodig hebt
  1. Samsung Galaxy S4 MicroSD Card Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy S4 MicroSD Card Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 MicroSD Card Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy S4 MicroSD Card Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy S4 MicroSD Card Replacement: stap 2, afbeelding 3 van 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Antwoord
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Antwoord
  3. Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: stap 3, afbeelding 1 van 3 Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: stap 3, afbeelding 2 van 3 Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: stap 3, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.647 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.732 handleidingen geschreven
Één opmerking
If you use Micro SD card the you must know to How to Recover Memory Card
we are not going to use any app/softwares we only use CMD and 5 exclusive methods
http://www.gogorapid.com/how-to-recover-...
Ramal jayaratna - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 87,521
