Ga door naar hoofdinhoud
Samsung Galaxy S4 Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy S4 Battery Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy S4 Battery Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Battery Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy S4 Battery Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy S4 Battery Replacement: stap 2, afbeelding 3 van 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Antwoord
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Antwoord
  3. Samsung Galaxy S4 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Samsung Galaxy S4 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Samsung Galaxy S4 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    it worked for me
    John Donovan - Antwoord
Conclusie
99 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.777 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
Één opmerking
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
Mark Cosenza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 114
Altijd: 87,105
