Ga door naar hoofdinhoud
Inleiding
Use this guide to learn how to replace a defective vibrator on your Samsung Galaxy S4 Active.
  1. Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: step 1, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Vibrator Replacement, MicroSD Card: step 2, image 1 of 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Vibrator Replacement, Battery: step 3, image 1 of 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Vibrator Replacement, SIM Card: step 4, image 1 of 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Vibrator Replacement, Midframe: step 5, image 1 of 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Vibrator Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: step 7, image 1 of 3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: step 7, image 2 of 3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: step 7, image 3 of 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Vibrator Replacement: step 8, image 1 of 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Vibrator Replacement: step 9, image 1 of 1
    • Remove the motherboard.
  10. Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: step 10, image 1 of 2 Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: step 10, image 2 of 2
    • Use tweezers to gently remove the vibrator.
Conclusie
3 andere personen hebben deze handleiding voltooid.
atika5656
167 Reputatie
1 Handleiding geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 3,504
