Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
how to replace the charging port for samsung galaxy 4 active att SGH I537
  1. Remove back cover Remove battery
    • Remove back cover
    • Remove battery
  2. remove battery before taking off screws
    • remove battery before taking off screws
    • remove the 8 screws in the back using a small Phillips screw driver
  3. using a prying tool or something remove the 4 covers that are blocking the last 4 screws
    • using a prying tool or something remove the 4 covers that are blocking the last 4 screws
    • you might have to put a bit of pressure to get them off
  4. Remove the 4 screws with a prying tool or fingers go around the edges to  remove the plastic back part of the phone
    • Remove the 4 screws
    • with a prying tool or fingers go around the edges to remove the plastic back part of the phone
    • be carefull not to break it by using too much force
  5. Remove these 2 screws then take off the white plastic part
    • Remove these 2 screws then take off the white plastic part
  6. use prying tool or finger to unplug antenna cable
    • use prying tool or finger to unplug antenna cable
    • be extra careful unplugging this
  7. use prying tool or fingers to unplug this connection
    • use prying tool or fingers to unplug this connection
    • again be careful
  8. you can now use the prying tool or fingers to remove the charging port and replace it with the new one follow steps in reverse to resemble
    • you can now use the prying tool or fingers to remove the charging port and replace it with the new one
    • follow steps in reverse to resemble
    • carefully
Conclusie
16 andere personen hebben deze handleiding voltooid.
ted582 ted583
521 Reputatie
1 Handleiding geschreven
Good tear down procedure.
tcjd1976 - Antwoord
I replaced Charging Port on my Samsung SGH-i537 about a week ago (Before I found this “Tear-Down Procedure”.)! You did a nice job putting this information together!
It’s relatively simple, although sometimes I feel like “the more information the better”!
I DO HAVE A QUESTION: After I removed the screws, and separated the two halves of my phone, I turned the front half face-up, and a small, flat, black clip I didn’t notice, fell from SOMEWHERE! Despite my looking for many various possibilities as to where this clip goes back into my phone, I didn't find a place that it would fit properly. I’m sure it’s location is staring me in the face, but I’m still not finding it!
After a whole lot more looking, one square centimeter at a time, I reluctantly decided to put my phone back together without this “clip”.
The phone works great! But I know this “clip” was in it for a reason, so I’m having a hard time calling this repair a complete success!
Does anybody know exactly where this “clip” goes?
Thanks!
Roger.
Roger C. Smith - Antwoord
I think it holds the midframe in. No worries, my midframe stays in with 3 screws.
[deleted] -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 7,364
