Ga door naar hoofdinhoud
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je Samsung Galaxy S22 Ultra te repareren, gebruik onze reparatiehandleidingen.
  1. Samsung Galaxy S22 Ultra Chip ID, Main Board Side 1: stap 1, afbeelding 1 van 2 Samsung Galaxy S22 Ultra Chip ID, Main Board Side 1: stap 1, afbeelding 2 van 2
    • IC Identification Pt. 1:
    • Qualcomm SM8450 Snapdragon 8 Gen 1 Octa-Core Processor layered under a Samsung K3LK7K70BM-BGCP 8 GB Mobile LPDDR5 SDRAM Memory
    • Samsung KLUDG4UHDC-B0E1 128 GB NAND Flash Memory (UFS 3.1)
    • Wacom WEZ02 Digitizer Controller
    • Maxim MAX77705C Power Management
    • Renesas P9320S Wireless Power Transceiver
    • NXP Semiconductor PCA9468 Battery Charger
    • Cirrus Logic CS35L40 Audio Amplifier
  2. Samsung Galaxy S22 Ultra Chip ID: stap 2, afbeelding 1 van 1
    • IC Identification, pt. 2:
    • Cirrus Logic CS40L26 Haptic Driver
    • Qualcomm PMR735A Power Management
    • Qualcomm PM3003 Power Management
    • Diodes Incorporated AP7340D-30FS4-7 150 mA / 3.0 V LDO Regulator
    • Diodes Incorporated AP7340D-33FS4-7 150 mA / 3.3 V LDO Regulator
    • Knowles MEMS Microphone
    • Qualcomm PMK8450 ? Clock Generator
  3. Samsung Galaxy S22 Ultra Chip ID: stap 3, afbeelding 1 van 1
    • IC Identification Pt. 3:
    • Qualcomm SDR735 RF Transceiver
    • Qualcomm SMR546 RF Transceiver
    • NXP Semiconductor SN220U NFC Controller w/ Secure Element
    • NXP Semiconductor SR100T Ultra-Wideband SoC
    • NXP Semiconductor BGU8103 GPS / GLONASS / Galileo / BeiDou Low Noise Amplifier
    • Qualcomm QET5100 Envelope Tracker
  4. Samsung Galaxy S22 Ultra Chip ID: stap 4, afbeelding 1 van 1
    • IC Identification pt. 4 (sensors):
    • Austria Microelectronics Ambient Light/Color/Gesture/Proximity Sensor
    • STMicroelectronics 6-Axis Accelerometer & Gyroscope
  5. Samsung Galaxy S22 Ultra Chip ID, Main Board Side 2: stap 5, afbeelding 1 van 2 Samsung Galaxy S22 Ultra Chip ID, Main Board Side 2: stap 5, afbeelding 2 van 2
    • IC Identification pt. 1:
    • Qualcomm PM8350 Power Management
    • Qualcomm PM8350C Power Management
    • Qualcomm PM8450 Power Management
    • Samsung S2MPB02 Power Management
    • Samsung S2MPBA3 Power Management
    • Goertek MEMS Microphone
  6. Samsung Galaxy S22 Ultra Chip ID: stap 6, afbeelding 1 van 1
    • IC Identification, pt 2:
    • Vishay DG2730 2-Port DPDT Analog Switch
  7. Samsung Galaxy S22 Ultra Chip ID: stap 7, afbeelding 1 van 1
    • IC Identification pt. 3:
    • Broadcom BCM4389 Wi-Fi 6E & Bluetooth 5.0
    • Broadcom AFEM-9146 Front-End Module
    • Skyworks SKY58083-11 Front-End Module
    • Qualcomm QPM6815 Front-End Module
    • Qualcomm QDM3572 Antenna Switch Module
    • Qorvo 2389 RF Power Amplifier (likely)
    • Qorvo 5389 RF Power Amplifier (likely)
    Qorvo 2389 is WIFI 2G FEM from Qorvo, and Qorvo 5389 is WIFI 5G FEM from Qorvo.
    xiajinggai - Antwoord
  8. Samsung Galaxy S22 Ultra Chip ID: stap 8, afbeelding 1 van 1
    • IC Identification pt. 4 (Sensors):
    • AKM Semiconductor 3-Axis Electronic Compass
    • STMicroelectronics Pressure Sensor
8 opmerkingen
Is there a way to contact the person that did this teardown? It would be great if I can ask about additional devices on the S22 smartphone.
Jae - Antwoord
Where is the esim located?
Buncha Stocks - Antwoord
on my ( Prime Day 22) Samsung S S22 Ultra , all 3 side buttons have recessed into body of phone. I finally got it to turn on but accessing the buttons moving forward will require a tiny flat head screw driver.. Paper clip slipped , my 1 fingernail finally turned it on so I'd find a solution. I've had mobile phones since 1996 and have never seen anything like this before . I had a Bumper case on back, had trouble removing it. I hadnt noticed the situation till tonight
Holly VH, Snoop&Fuzzy - Antwoord
what shd I do? I'm not "sucking on my phone".
My power button has just fallen off. Can't find a green one to replace it myself, probably because they don't make an s22 ultra in green for the Chinese market, and that's where all the power buttons are located. So red (burgundy) and black are my choices; incidentally, the volume rocker is included with the power butto Which accent would look better on the s22 ultra in green? Or would the s22 plus or s22 buttons be interchangeable?
Glenn -
please i need help with my 22 ultra, it fell and the screen wont display anything, it is not broken, the phone still works and i hear sound and receive calls but the display is blank, now the screen was changed and it still does not display anything, please what do i do, important doc on this phone i cant connect it to pc because i need to enter password n allow access. any advice? my email = frankasiboje@gmail.com
frank Steel - Antwoord
I need for Samsung s22 ultra U3004 IC Transceiver SM-G908E
How can I order ?
Jahongir Mamadiyorov - Antwoord
Es divertido reparador utilizar el conocimiento de tal eminencia para germinar una experiencia q,nunca has tenido y te arriesgas guao gracias maestro ok
ANDRES MARTINEZ RENTERIA - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 35
Afgelopen 7 dagen: 176
Afgelopen 30 dagen: 710
Altijd: 35,552
