Ga door naar hoofdinhoud
Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement
Wat je nodig hebt
  1. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Midframe: stap 3, afbeelding 1 van 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 4, afbeelding 1 van 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 5, afbeelding 3 van 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: stap 6, afbeelding 2 van 2
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: stap 7, afbeelding 1 van 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: stap 7, afbeelding 2 van 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
Conclusie
Taylor Catlin
79 Reputatie
6 handleidingen geschreven
Cal Poly, Team 18-37, Regan Winter 2013 Lid van Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 4,232
