Ga door naar hoofdinhoud
Samsung Galaxy S Vibrant Midframe Replacement
Wat je nodig hebt
  1. Samsung Galaxy S Vibrant Midframe Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Midframe Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy S Vibrant Midframe Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Midframe Replacement, Midframe: stap 3, afbeelding 1 van 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Midframe Replacement: stap 4, afbeelding 1 van 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Midframe Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy S Vibrant Midframe Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy S Vibrant Midframe Replacement: stap 5, afbeelding 3 van 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Midframe Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S Vibrant Midframe Replacement: stap 6, afbeelding 2 van 2
    • Slide the SD card out of its slot.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Krista Purser
212 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-37, Regan Winter 2013 Lid van Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,599
