Ga door naar hoofdinhoud
Inleiding
Is your battery not maintaining a desired lifespan? Is it acting up sporadically causing your phone to turn off on its own? It might be worth it to replace it. Follow these steps for the removal and installation of a new battery.
If your battery is swollen, take appropriate precautions.
  1. Samsung Galaxy S Vibrant Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy S Vibrant Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
Conclusie
Taylor Catlin
79 Reputatie
6 handleidingen geschreven
Cal Poly, Team 18-37, Regan Winter 2013 Lid van Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Leden
7 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,531
