Ga door naar hoofdinhoud
Samsung Galaxy S III Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy S III Battery Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement: stap 2, afbeelding 2 van 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Battery Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement: stap 3, afbeelding 2 van 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement: stap 4, afbeelding 2 van 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Battery Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement: stap 5, afbeelding 2 van 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Battery Replacement, Battery: stap 6, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement, Battery: stap 6, afbeelding 2 van 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Battery Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy S III Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove the battery.
Conclusie
90 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - Antwoord
Super simple. Thanks!
bmwherry - Antwoord
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 70
Altijd: 64,934
