Ga door naar hoofdinhoud
Samsung Galaxy S II T989 Speaker Replacement
Wat je nodig hebt
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: stap 1, afbeelding 1 van 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: stap 1, afbeelding 2 van 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: stap 1, afbeelding 3 van 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: stap 2, afbeelding 1 van 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: stap 2, afbeelding 2 van 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: stap 2, afbeelding 3 van 3
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. Samsung Galaxy S II T989 Speaker Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy S II T989 Speaker Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy S II T989 Speaker Replacement: stap 3, afbeelding 3 van 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: stap 4, afbeelding 1 van 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: stap 4, afbeelding 2 van 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: stap 4, afbeelding 3 van 3
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
Conclusie
Joshua King
1.345 Reputatie
9 handleidingen geschreven
Clemson, Team 1-5, Benson Spring 2014 Lid van Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Leden
3 opmerkingen
speaker jumper ways
Muhammad azan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,452
