Ga door naar hoofdinhoud
Inleiding
The most common use of the SIM card is for storing contacts and synchronizing with your mobile carrier. This small part is vital to the operation of the phone since it directly affects the ability to receive calls and messages as well as creating interruptions of service.
  1. Samsung Galaxy S II T989 SIM Card Replacement, Rear Cover: stap 1, afbeelding 1 van 3 Samsung Galaxy S II T989 SIM Card Replacement, Rear Cover: stap 1, afbeelding 2 van 3 Samsung Galaxy S II T989 SIM Card Replacement, Rear Cover: stap 1, afbeelding 3 van 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 SIM Card Replacement, SIM Card: stap 2, afbeelding 1 van 3 Samsung Galaxy S II T989 SIM Card Replacement, SIM Card: stap 2, afbeelding 2 van 3 Samsung Galaxy S II T989 SIM Card Replacement, SIM Card: stap 2, afbeelding 3 van 3
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
Conclusie
Joshua King
1.330 Reputatie
9 handleidingen geschreven
Clemson, Team 1-5, Benson Spring 2014 Lid van Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Leden
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 2,567
