Ga door naar hoofdinhoud
Samsung Galaxy S II Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy S II Screen Replacement, Remove back cover: stap 1, afbeelding 1 van 1
    • Gently remove the back cover starting from the slot given on the right side.
  2. Samsung Galaxy S II Screen Replacement, Remove battery: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the battery from the slot.
    • Carefully place the battery away from some hot object or fire.
  3. Samsung Galaxy S II Screen Replacement, Remove back case screws: stap 3, afbeelding 1 van 1
    • Use a magnetic philips #0 head screw driver to open the 7 x 1/16 in (1.6 mm) philips head screws shown in the image.
    • Place the screws carefully in a box.
  4. Samsung Galaxy S II Screen Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy S II Screen Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy S II Screen Replacement: stap 4, afbeelding 3 van 3
    • Gently unlock the snap locks starting from the top left corner and progressing along the perimeter to remove the back case.
    • To unlock the snaps, apply force close to the snap in order to avoid cracking of the plastic cover.
    • Remove the plastic cover carefully and place on the white paper.
  5. Samsung Galaxy S II Screen Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement: stap 5, afbeelding 2 van 2
    • Use a screwdriver or another pointed tool to disconnect the screen connector.
    • Lift the cable out of the slot.
    • Gently handle the cable to avoid damage to the cable or the connector.
  6. Samsung Galaxy S II Screen Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the connector for the speaker and audio jack carefully.
    • Gently lift the cable to avoid damage to the cable or the connector.
  7. Samsung Galaxy S II Screen Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy S II Screen Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy S II Screen Replacement: stap 7, afbeelding 3 van 3
    • Use a screwdriver to gently lift the speaker which is fixed to the base with double side tape.
    • Gently lift the earpiece using a flat screwdriver.
  8. Samsung Galaxy S II Screen Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy S II Screen Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy S II Screen Replacement: stap 8, afbeelding 3 van 3
    • Unplug the secondary camera connector carefully and lift the cable.
    • Then unplug the connector that receives the input from the screen.
    • Remove the connection for the charging port using a screw driver.
    • Handle carefully to avoid tearing off the cable.
  9. Samsung Galaxy S II Screen Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the two 1.6 mm black head screws using the Phillips #00 screwdriver.
  10. Samsung Galaxy S II Screen Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement: stap 10, afbeelding 2 van 2
    • Disconnect the antennae from both the ends by removing the connections using flat screwdriver.
    • Carefully pull out the antennae cable from the slot.
  11. Samsung Galaxy S II Screen Replacement: stap 11, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement: stap 11, afbeelding 2 van 2
    • Gently peel off the power button fixed with double adhesive tape.
    • Carefully lift the button out of the slot.
    • Try to keep the double side tape on the button and handle the cable carefully to avoid tearing the ribbon.
  12. Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: stap 12, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: stap 12, afbeelding 2 van 2
    • Repeat the same procedure from step 15 to remove the volume up down button.
  13. Samsung Galaxy S II Screen Replacement, Remove main board: stap 13, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement, Remove main board: stap 13, afbeelding 2 van 2
    • Now the main board is free. Carefully lift it up and place on the workbench gently.
  14. Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: stap 14, afbeelding 1 van 2 Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: stap 14, afbeelding 2 van 2
    • Peel off the ribbon cable connecting the charging port and microphone by hand.
  15. Samsung Galaxy S II Screen Replacement, Unscrew charging module: stap 15, afbeelding 1 van 1
    • Remove the two 2.0 mm screws using the Phillips #0 screwdriver.
  16. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: stap 16, afbeelding 1 van 3 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: stap 16, afbeelding 2 van 3 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: stap 16, afbeelding 3 van 3
    • Lift the microphone gently.
    • Lift the board out from the metal casing and place on the workbench.
  17. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: stap 17, afbeelding 1 van 3 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: stap 17, afbeelding 2 van 3 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: stap 17, afbeelding 3 van 3
    • Finally push the screen out applying force through the screwdriver at the highlighted locations.
    • Take out the screen, clean the remaining double side tape and adhesive.
    • Install the new screen and follow the same steps in reverse order to re assemble the phone.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Bader
337 Reputatie
1 Handleiding geschreven
Één opmerking
My Samsung Galaxy s2 is an AT&T phone
Anthony Godoy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 1,768
