Ga door naar hoofdinhoud
Samsung Galaxy R Speaker Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy R Speaker Assembly Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Speaker Assembly Replacement, Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy R Speaker Assembly Replacement, Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy R Speaker Assembly Replacement, Battery: stap 2, afbeelding 3 van 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Speaker Assembly Replacement, Remove screws: stap 3, afbeelding 1 van 2 Samsung Galaxy R Speaker Assembly Replacement, Remove screws: stap 3, afbeelding 2 van 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: stap 4, afbeelding 1 van 3 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: stap 4, afbeelding 2 van 3 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: stap 4, afbeelding 3 van 3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Gently lift the bottom panel from the back of the phone.
  5. Samsung Galaxy R Speaker Assembly Replacement, Top Panel: stap 5, afbeelding 1 van 3 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: stap 5, afbeelding 2 van 3 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: stap 5, afbeelding 3 van 3
    • Use tweezers to grasp the vibrator piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Speaker Assembly Replacement, Speaker: stap 6, afbeelding 1 van 3 Samsung Galaxy R Speaker Assembly Replacement, Speaker: stap 6, afbeelding 2 van 3 Samsung Galaxy R Speaker Assembly Replacement, Speaker: stap 6, afbeelding 3 van 3
    • The speaker is located near the top of the phone underneath the motherboard circled in red.
    • To remove the speaker, gently pull on the strap attached until it releases from the phone.
Conclusie
Daniel Hawkins
334 Reputatie
2 handleidingen geschreven
Clemson, Team 3-3, Benson Fall 2014 Lid van Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 364
