Ga door naar hoofdinhoud
Samsung Galaxy R Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy R Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy R Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy R Motherboard Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Motherboard Replacement, Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy R Motherboard Replacement, Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy R Motherboard Replacement, Battery: stap 2, afbeelding 3 van 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Motherboard Replacement, Screws: stap 3, afbeelding 1 van 2 Samsung Galaxy R Motherboard Replacement, Screws: stap 3, afbeelding 2 van 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Motherboard Replacement, Bottom Panel: stap 4, afbeelding 1 van 3 Samsung Galaxy R Motherboard Replacement, Bottom Panel: stap 4, afbeelding 2 van 3 Samsung Galaxy R Motherboard Replacement, Bottom Panel: stap 4, afbeelding 3 van 3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Motherboard Replacement, Top Panel: stap 5, afbeelding 1 van 3 Samsung Galaxy R Motherboard Replacement, Top Panel: stap 5, afbeelding 2 van 3 Samsung Galaxy R Motherboard Replacement, Top Panel: stap 5, afbeelding 3 van 3
    • Use tweezers to grasp the circular silver metal piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Motherboard Replacement, Remove Motherboard: stap 6, afbeelding 1 van 1
    • If you want to replace motherboard, gently pull motherboard from the back of the phone.
    • The parts indicated in red color are attached by adhesive to the back of the phone, so more force will be necessary to remove these areas.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Keon Horahan
841 Reputatie
6 handleidingen geschreven
Clemson, Team 3-3, Benson Fall 2014 Lid van Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 1,665
