Ga door naar hoofdinhoud
Samsung Galaxy R Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy R Headphone Jack Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy R Headphone Jack Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy R Headphone Jack Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Headphone Jack Replacement, Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy R Headphone Jack Replacement, Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy R Headphone Jack Replacement, Battery: stap 2, afbeelding 3 van 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Headphone Jack Replacement, Screws: stap 3, afbeelding 1 van 2 Samsung Galaxy R Headphone Jack Replacement, Screws: stap 3, afbeelding 2 van 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 1 van 3 Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 2 van 3 Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 3 van 3
    • The headphone jack is located near the top left side of the motherboard.
    • To remove the headphone jack, gently pull on the area indicated in red until it detaches from the motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Keon Horahan
841 Reputatie
6 handleidingen geschreven
Clemson, Team 3-3, Benson Fall 2014 Lid van Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,355
