Ga door naar hoofdinhoud
Samsung Galaxy R Front Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Front Facing Camera Replacement, Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: stap 2, afbeelding 3 van 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: stap 3, afbeelding 1 van 2 Samsung Galaxy R Front Facing Camera Replacement, Remove screws: stap 3, afbeelding 2 van 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 1 van 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 2 van 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 3 van 3
    • The front facing camera is located in the top right corner of the back of the phone.
    • To remove the camera, gently pull until it detaches from the motherboard.
Conclusie
Keon Horahan
841 Reputatie
6 handleidingen geschreven
Clemson, Team 3-3, Benson Fall 2014 Lid van Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 345
