Ga door naar hoofdinhoud
Samsung Galaxy Prime Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Prime Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert a small spudger or fingernail into the tab that is located on the power button side of the phone and then try to pry up.
    • After the initial lift, go around the edges of the back cover lifting it up to release.
  2. Samsung Galaxy Prime Battery Replacement: stap 2, afbeelding 1 van 1
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Prime Battery Replacement: stap 3, afbeelding 1 van 1
    • Insert the new battery in the reverse order from taking out the battery, ensuring the metal contacts from the phone are touching the flat metal contacts on the battery. Then place another edge of battery in the bay.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Khristina Manivanh
150 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G1, Liner Summer 2018 Lid van UW Tacoma, Team S1-G1, Liner Summer 2018
UWT-LINER-SU18S1G1
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 37
Altijd: 1,412
