Ga door naar hoofdinhoud
Samsung Galaxy Prevail Touch Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy Prevail Touch Screen Replacement, Touch Screen: stap 1, afbeelding 1 van 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Touch Screen Replacement: stap 2, afbeelding 1 van 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Touch Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Touch Screen Replacement: stap 4, afbeelding 1 van 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Touch Screen Replacement: stap 5, afbeelding 1 van 1
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Touch Screen Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
    • The shield plate will not be fully removed, it is attached to the front panel with a ribbon cable.
  7. Samsung Galaxy Prevail Touch Screen Replacement: stap 7, afbeelding 1 van 1
    • Using the spudger lift up the LCD screen and replace with the new screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ricardo Zuloaga
525 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-6, Blackwell Fall 2016 Lid van USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 758
