Ga door naar hoofdinhoud
Samsung Galaxy Prevail Rear Speaker Replacement
Wat je nodig hebt
  1. Samsung Galaxy Prevail Rear Speaker Replacement, Rear Speaker: stap 1, afbeelding 1 van 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The motherboard will now be accessible.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Speaker Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Prevail Rear Speaker Replacement: stap 5, afbeelding 2 van 2
    • Using the spudger, carefully lift upward to remove the speaker assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
Conclusie
Ricardo Zuloaga
525 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-6, Blackwell Fall 2016 Lid van USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 225
