Ga door naar hoofdinhoud
Samsung Galaxy Prevail Rear Camera Lens Replacement
Wat je nodig hebt
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: stap 1, afbeelding 1 van 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: stap 2, afbeelding 1 van 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: stap 3, afbeelding 1 van 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: stap 4, afbeelding 1 van 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: stap 5, afbeelding 1 van 1
    • Replace the secondary rear panel which has the camera lens attached.
Conclusie
Ricardo Zuloaga
537 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-6, Blackwell Fall 2016 Lid van USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 313
