Ga door naar hoofdinhoud
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: stap 1, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: stap 1, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: stap 1, afbeelding 3 van 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: stap 2, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: stap 2, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: stap 2, afbeelding 3 van 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: stap 3, afbeelding 1 van 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: stap 3, afbeelding 2 van 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: stap 4, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: stap 4, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: stap 4, afbeelding 3 van 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: stap 5, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: stap 5, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: stap 5, afbeelding 3 van 3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: stap 6, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: stap 6, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: stap 6, afbeelding 3 van 3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: stap 7, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: stap 7, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: stap 7, afbeelding 3 van 3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: stap 8, afbeelding 1 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: stap 8, afbeelding 2 van 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: stap 8, afbeelding 3 van 3
    • Carefully lift and remove the camera from its position.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Alexandra Hernandez
741 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-4, Leahy Fall 2014 Lid van USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,351
