Inleiding
How to disassemble the phone and change broken Digitizer / Glass or LCD Display.
________________________Vedeo manual:________________________
Wat je nodig hebt
Video overzicht
Remove any SIM and SD card.
Remove 7x Phillips screws.
Use a plastic tool to disassemble the rear housing.
Disconnect the LCD Display flex cable.
Lift up the board and disconnect the Touchscreen flex cable.
Now you can remove the Motherboard.
Warm the touchscreen to make separating the LCD Display more easy
In the four corners of LCD display there are small metal plates. Use one of them to lift a little the LCD and put the plastic tool.
Be careful not to break the display.
3 andere personen hebben deze handleiding voltooid.
