Inleiding
The Samsung Galaxy On5 comes with two cameras, one front-facing and one rear-facing camera. This guide will walk you through replacing both.
Wat je nodig hebt
Use a plastic pry tool to lift the front-facing camera from its housing.
Using a Phillips #00 screwdriver, remove the screw securing the rear-facing camera.
That's it, now you've removed both the front and rear facing cameras on your device! To reassemble your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
