Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
Press down until the SIM Card Tray begins to protrude out of the device.
Heat the back of the device with a heat gun for 2 minutes
Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
While pulling upwards, insert a pick under the rear glass
Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
Once all adhesive has been cut, gently lift up the rear glass to remove it.
Remove 20 5mm screws with a Phillips #1 Screwdriver.
Grip the back of the device and press down on the white square to remove the middle housing.
Loosen the power button flex adhesive by holding it with the tweezers.
With the tweezers, pry up and remove the power button flex
Push out the power button with the tip of the tweezers.
Één andere persoon heeft deze handleiding voltooid.
