Ga door naar hoofdinhoud
Samsung Galaxy Note5 Power Button Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note5 Power Button Replacement, SIM Card Tray: stap 1, afbeelding 1 van 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Power Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Power Button Replacement, Power Button: stap 3, afbeelding 1 van 1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Power Button Replacement: stap 4, afbeelding 1 van 1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Power Button Replacement: stap 5, afbeelding 1 van 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Power Button Replacement: stap 6, afbeelding 1 van 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Power Button Replacement: stap 7, afbeelding 1 van 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Power Button Replacement: stap 8, afbeelding 1 van 1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Power Button Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Note5 Power Button Replacement: stap 9, afbeelding 2 van 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Power Button Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Note5 Power Button Replacement: stap 10, afbeelding 2 van 2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Power Button Replacement: stap 11, afbeelding 1 van 2 Samsung Galaxy Note5 Power Button Replacement: stap 11, afbeelding 2 van 2
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Power Button Replacement: stap 12, afbeelding 1 van 1
    • Push out the power button with the tip of the tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bernice Nunez
340 Reputatie
2 handleidingen geschreven
Cal Poly, Team S25-G17, Maness Spring 2018 Lid van Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 2,853
