Ga door naar hoofdinhoud
Samsung Galaxy Note Vibrator Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Vibrator Replacement, Stylus: stap 1, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement, Stylus: stap 1, afbeelding 2 van 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Vibrator Replacement, Rear Case: stap 2, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement, Rear Case: stap 2, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Vibrator Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement: stap 3, afbeelding 2 van 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Vibrator Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement, Battery: stap 4, afbeelding 2 van 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Vibrator Replacement, MicroSD Card: stap 5, afbeelding 1 van 3 Samsung Galaxy Note Vibrator Replacement, MicroSD Card: stap 5, afbeelding 2 van 3 Samsung Galaxy Note Vibrator Replacement, MicroSD Card: stap 5, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Vibrator Replacement: stap 6, afbeelding 1 van 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Vibrator Replacement, SIM Card: stap 7, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement, SIM Card: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Vibrator Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement: stap 8, afbeelding 2 van 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Vibrator Replacement, Midframe: stap 9, afbeelding 1 van 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Vibrator Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement: stap 10, afbeelding 2 van 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Vibrator Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy Note Vibrator Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy Note Vibrator Replacement: stap 11, afbeelding 3 van 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Vibrator Replacement: stap 12, afbeelding 1 van 3 Samsung Galaxy Note Vibrator Replacement: stap 12, afbeelding 2 van 3 Samsung Galaxy Note Vibrator Replacement: stap 12, afbeelding 3 van 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Vibrator Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement: stap 13, afbeelding 2 van 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Vibrator Replacement, Motherboard Assembly: stap 14, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement, Motherboard Assembly: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Vibrator Replacement: stap 15, afbeelding 1 van 3 Samsung Galaxy Note Vibrator Replacement: stap 15, afbeelding 2 van 3 Samsung Galaxy Note Vibrator Replacement: stap 15, afbeelding 3 van 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Vibrator Replacement: stap 16, afbeelding 1 van 3 Samsung Galaxy Note Vibrator Replacement: stap 16, afbeelding 2 van 3 Samsung Galaxy Note Vibrator Replacement: stap 16, afbeelding 3 van 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Vibrator Replacement: stap 17, afbeelding 1 van 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Vibrator Replacement: stap 18, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement: stap 18, afbeelding 2 van 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Vibrator Replacement, Vibrator: stap 19, afbeelding 1 van 3 Samsung Galaxy Note Vibrator Replacement, Vibrator: stap 19, afbeelding 2 van 3 Samsung Galaxy Note Vibrator Replacement, Vibrator: stap 19, afbeelding 3 van 3
    • Insert the tip of a spudger under the vibrator connector cable near the contacts then slide it toward the vibrator itself.
  20. Samsung Galaxy Note Vibrator Replacement: stap 20, afbeelding 1 van 2 Samsung Galaxy Note Vibrator Replacement: stap 20, afbeelding 2 van 2
    • Insert the flat end of a spudger under the vibrator connector cable and pry it up from the adhesive.
  21. Samsung Galaxy Note Vibrator Replacement: stap 21, afbeelding 1 van 1
    • Remove the vibrator from the display assembly.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.738 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.767 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 6,116
