Ga door naar hoofdinhoud
Samsung Galaxy Note Pro 12.2 Audio Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement, Audio Jack: stap 1, afbeelding 1 van 1
    • Make sure that your device is powered off before starting your repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
  3. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 3, afbeelding 1 van 1
    • Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
  4. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 3mm Phillips #00 screws over the silver cover.
    • The silver cover is attached to the whole audio jack; do not try to pull this away by itself.
  5. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 5, afbeelding 2 van 2
    • Pop up the green connecter by gently pulling up.
  6. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 6, afbeelding 2 van 2
    • Pull up on the circular amp with the spudger tool to release it from the device.
  7. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: stap 7, afbeelding 1 van 1
    • Remove the whole audio jack by pulling gently up on the copper piece.
    • This component is extremely fragile.
Conclusie
Tina Kong
1.278 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 671
