Ga door naar hoofdinhoud
Samsung Galaxy Note Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Motherboard Replacement, Stylus: stap 1, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement, Stylus: stap 1, afbeelding 2 van 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Motherboard Replacement, Rear Case: stap 2, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement, Rear Case: stap 2, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Motherboard Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Motherboard Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Motherboard Replacement, MicroSD Card: stap 5, afbeelding 1 van 3 Samsung Galaxy Note Motherboard Replacement, MicroSD Card: stap 5, afbeelding 2 van 3 Samsung Galaxy Note Motherboard Replacement, MicroSD Card: stap 5, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Motherboard Replacement, SIM Card: stap 7, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement, SIM Card: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Motherboard Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Motherboard Replacement, Midframe: stap 9, afbeelding 1 van 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Motherboard Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Motherboard Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy Note Motherboard Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy Note Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Motherboard Replacement: stap 12, afbeelding 1 van 3 Samsung Galaxy Note Motherboard Replacement: stap 12, afbeelding 2 van 3 Samsung Galaxy Note Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Motherboard Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: stap 14, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Motherboard Replacement: stap 15, afbeelding 1 van 3 Samsung Galaxy Note Motherboard Replacement: stap 15, afbeelding 2 van 3 Samsung Galaxy Note Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Motherboard Replacement: stap 16, afbeelding 1 van 3 Samsung Galaxy Note Motherboard Replacement: stap 16, afbeelding 2 van 3 Samsung Galaxy Note Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Motherboard Replacement: stap 18, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: stap 19, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: stap 19, afbeelding 2 van 2
    • Use a plastic opening tool to flip the release tab on the rear-facing camera cable ZIF connector.
    • Only pry on the tab, not the connector itself.
  20. Samsung Galaxy Note Motherboard Replacement: stap 20, afbeelding 1 van 2 Samsung Galaxy Note Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Slide the tip of a spudger under the rear-facing camera cable to slide it out of the ZIF connector and free it from the light adhesive.
  21. Samsung Galaxy Note Motherboard Replacement: stap 21, afbeelding 1 van 1
    • Remove the rear-facing camera.
Conclusie
20 andere personen hebben deze handleiding voltooid.
Sam Goldheart
476.212 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
24.276 handleidingen geschreven
4Gids Commentaar
from where I can get the motherboard for Samsung Galaxy note 3???
abdom911 - Antwoord Deel
Can You Assist Me where can I purchase samsung GT- N7000 mother board. GALAXY NOTE 1
edcas2158 - Antwoord Deel
i need note 7000 motherboard
rajeev kapoor - Antwoord Deel
How much does it cost for buying a Samsung Galaxy Note4 motherboard ? And where will I get it in Bangalore
LIGHT BREEZE - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 50
Altijd: 37,243
