Ga door naar hoofdinhoud
Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Stylus: stap 1, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Stylus: stap 1, afbeelding 2 van 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Rear Case: stap 2, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Rear Case: stap 2, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 3, afbeelding 3 van 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: stap 4, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: stap 4, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: stap 4, afbeelding 3 van 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Battery: stap 5, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Battery: stap 5, afbeelding 2 van 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Midframe: stap 7, afbeelding 1 van 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    In my phone some of the screws are litterally not ot turn - I screwed up one of the heads - be careful!
    erich zalcmann - Antwoord
    I have 2 note 2 phones model #: SGH-I317M. I have a broken screen that does not display in my note 2 but my brother's note 2 is working perfectly. Can I either transfer the motherboard in MY note 2 to my brothers note 2 or swap the broken screen with the new screen in my brother's note 2 ? Thanks. Reach me at anmac1789@gmail.com
    An Mac - Antwoord
  8. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 8, afbeelding 3 van 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
    I didn't have an opening tool, so I used a stiff guitar pick. Worked like a charm.
    evanjpederson - Antwoord
    for best result without any scratches or breaking frame, open the frame on table (solid), don't open on hand.
    Chovav Sutachy - Antwoord
  9. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 9, afbeelding 3 van 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 10, afbeelding 2 van 2
    • Carefully pry around the corner with a plastic opening tool.
    The screen cracked using that plastic tool.
    hell0allis0n - Antwoord
  11. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 11, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 11, afbeelding 2 van 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 12, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 12, afbeelding 2 van 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 13, afbeelding 2 van 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
    Start with the top clip. You can see it located next to the three battery connectors. Insert the spludge from the side gently to push, the clip should go off.
    Once this clip is off, the bottom battery clip can be unclipped simply by gently moving the two pieces apart.
    anonymous 4780 - Antwoord
    Gan kalok bluetooth hp saya sama wifi nya nggak bisa nelusurin jaringan apa nya yg rusak apa gara gara udah di root
    aryadana55 -
    If you're primarily following the pictures, as I was, you might be frustrated that your display assembly isn't popping off. Unfortunately, a vital step was listed in the instructions but not photographed:
    "Lastly, there are two clips along the top and bottom edge of battery compartment that also hold the display assembly in place."
    alimac70117 - Antwoord
  14. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 14, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 14, afbeelding 2 van 2
    • Lift the display assembly out of the midframe.
    unblock the edge at the middle-up of the battery compart!
    Giorgio - Antwoord
  15. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Motherboard Assembly: stap 15, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Motherboard Assembly: stap 15, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Motherboard Assembly: stap 15, afbeelding 3 van 3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
    Dear Sirs,
    My Galaxy Note II is completely dead due to lightning in the house. I guess there is a fuse or a protection somewhere but I can not find it. Can you help ? Thanks in advance, Jose
    Jose - Antwoord
    One idea would be to track backwards, i.e. check to see if current is reaching from the charge port to the mainboard. Looking at the following picture http://d3nevzfk7ii3be.cloudfront.net/igi... it seems like the fuse is - as expected - located right by the USB port. If you're lucky it could be as easy as replacing the charging board, a $10 component.
    hakro807 -
    My Note II LTE does not have the antenna cable like here
    Bubbele - Antwoord
  16. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 16, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 16, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 16, afbeelding 3 van 3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  17. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 17, afbeelding 1 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 17, afbeelding 2 van 3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 17, afbeelding 3 van 3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  18. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 18, afbeelding 1 van 1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
    Is it possible to replace my Note II N7105 motherboard to N7100? Is there some negative effects happen, if i did it?
    Eduardo Lucas III - Antwoord
  19. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 19, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 19, afbeelding 2 van 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  20. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Headphone Jack/Earpiece Speaker Assembly: stap 20, afbeelding 1 van 1
    • Remove the 3 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
  21. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 21, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 21, afbeelding 2 van 2
    • Grasp the headphone jack portion of the assembly and lift it out of its groove in the display assembly.
  22. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 22, afbeelding 1 van 2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: stap 22, afbeelding 2 van 2
    • Gently pull the headphone jack straight up without twisting the cable to remove the earpiece speaker portion from its recess.
    • Twisting or pulling unevenly could damage the cable. Be very careful as you extract the assembly.
Conclusie
42 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.744 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.767 handleidingen geschreven
5 opmerkingen
Thanks for the help. I have fixit the my Headphone Jack/Earpiece Speaker easily with these tutorial. The only difficult was the reassemble the antenna cable connector.
Giorgio
Giorgio - Antwoord
Sooo, to replace the earpiece assembly, you have to bust your screen?
David - Antwoord
Did you use the miniature hammer for that step David?
Jasen Putney -
Where can I purchase a headphone jack to replace my defective one?
jimhyunglee - Antwoord
Installed everything correctly. Ear piece works fine, however my headphone jack (which was the faulty component in the first place) does not work at all. The phone does not even detect when I have a pair of earbuds plugged in. I replaced this piece due to heavy static out of the headphone jack.
Chris Del Sesto - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 57,443
