Ga door naar hoofdinhoud
Samsung Galaxy Note Front Facing Camera Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Stylus: stap 1, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Stylus: stap 1, afbeelding 2 van 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Rear Case: stap 2, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Rear Case: stap 2, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 3, afbeelding 2 van 2
    • Lift and remove the rear case from the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Battery: stap 4, afbeelding 2 van 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Galaxy Note Front Facing Camera Assembly Replacement, MicroSD Card: stap 5, afbeelding 1 van 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement, MicroSD Card: stap 5, afbeelding 2 van 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement, MicroSD Card: stap 5, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the microSD card from its slot in the midframe.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Galaxy Note Front Facing Camera Assembly Replacement, SIM Card: stap 7, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, SIM Card: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 8, afbeelding 2 van 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Midframe: stap 9, afbeelding 1 van 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 10, afbeelding 2 van 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 11, afbeelding 3 van 3
    • Slide the plastic opening tool down the seam.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 12, afbeelding 1 van 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 12, afbeelding 2 van 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 12, afbeelding 3 van 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 13, afbeelding 2 van 2
    • Remove the midframe from the display assembly.
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Upper Display Assembly Bracket: stap 14, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 15, afbeelding 1 van 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 16, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: stap 16, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
    Vraag FixBot
    Voeg opmerking toe
  17. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: stap 17, afbeelding 1 van 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: stap 17, afbeelding 2 van 2
    • Using tweezers, or your fingers, remove the front-facing camera assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Sam Goldheart
477.658 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
27.525 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 5,694
