Ga door naar hoofdinhoud
Samsung Galaxy Note Edge Volume Button Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: stap 1, afbeelding 1 van 2 Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: stap 1, afbeelding 2 van 2
    • Place your device flat down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
  2. Samsung Galaxy Note Edge Volume Button Replacement: stap 2, afbeelding 1 van 1
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
  3. Samsung Galaxy Note Edge Volume Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the stylus from its sheathe.
  4. Samsung Galaxy Note Edge Volume Button Replacement: stap 4, afbeelding 1 van 1
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
  5. Samsung Galaxy Note Edge Volume Button Replacement: stap 5, afbeelding 1 van 1
    • Use a Spudger to remove the black chassis and expose the motherboard.
  6. Samsung Galaxy Note Edge Volume Button Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 6, afbeelding 3 van 3
    • Use a Spudger to disconnect the following connections:
    • Connection 1
    • Connection 2
    • Connection 3
  7. Samsung Galaxy Note Edge Volume Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the connection for the front camera.
  8. Samsung Galaxy Note Edge Volume Button Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 8, afbeelding 3 van 3
    • Do not try to completely remove the motherboard until the final step.
    • Use a Spudger to gently lift the motherboard.
    • Remove the connection of the motherboard and the daughter board.
    • Remove the motherboard.
  9. Samsung Galaxy Note Edge Volume Button Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 9, afbeelding 3 van 3
    • Remove the volume button panel.
    • Remove the volume button connection.
    • Remove the volume button entirely.
Conclusie
Lizzie Todd
301 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G1, Harley Spring 2019 Lid van IUPUI, Team S1-G1, Harley Spring 2019
IUPUI-HARLEY-S19S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 395
