Ga door naar hoofdinhoud
Inleiding
If you are unable to adjust the volume on your device, the volume switch may be faulty. Use this guide to replace the volume button in your device.
Onderdelen
Geen onderdelen opgegeven.
  1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: stap 1, afbeelding 1 van 2 Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: stap 1, afbeelding 2 van 2
    • Place your device flat down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
  2. Samsung Galaxy Note Edge Volume Button Replacement: stap 2, afbeelding 1 van 1
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
  3. Samsung Galaxy Note Edge Volume Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the stylus from its sheathe.
  4. Samsung Galaxy Note Edge Volume Button Replacement: stap 4, afbeelding 1 van 1
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
  5. Samsung Galaxy Note Edge Volume Button Replacement: stap 5, afbeelding 1 van 1
    • Use a Spudger to remove the black chassis and expose the motherboard.
  6. Samsung Galaxy Note Edge Volume Button Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 6, afbeelding 3 van 3
    • Use a Spudger to disconnect the following connections:
    • Connection 1
    • Connection 2
    • Connection 3
  7. Samsung Galaxy Note Edge Volume Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the connection for the front camera.
  8. Samsung Galaxy Note Edge Volume Button Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 8, afbeelding 3 van 3
    • Do not try to completely remove the motherboard until the final step.
    • Use a Spudger to gently lift the motherboard.
    • Remove the connection of the motherboard and the daughter board.
    • Remove the motherboard.
  9. Samsung Galaxy Note Edge Volume Button Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy Note Edge Volume Button Replacement: stap 9, afbeelding 3 van 3
    • Remove the volume button panel.
    • Remove the volume button connection.
    • Remove the volume button entirely.
Conclusie
Lizzie Todd
301 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G1, Harley Spring 2019 Lid van IUPUI, Team S1-G1, Harley Spring 2019
IUPUI-HARLEY-S19S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 293
