Ga door naar hoofdinhoud
Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 2, afbeelding 3 van 3
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 4, afbeelding 3 van 3
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 5, afbeelding 2 van 2
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 6, afbeelding 3 van 3
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 7, afbeelding 3 van 3
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
  8. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement, Ear Speaker and Power Button: stap 8, afbeelding 1 van 1
    • Gently insert the pointed end of your spudger under the gold ribbon connecting the speaker and power button.
    • Lift the ribbon to disconnect it from the frame.
  9. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: stap 9, afbeelding 2 van 2
    • Insert the pointed end of spudger under an edge on the left side of the phones speaker.
    • Gently pry the speaker and power button from its home.
    • Carefully remove the power button from the device.
    • To reassemble, the Power Button must be inserted back in first.
Conclusie
Duc Huynh
253 Reputatie
2 handleidingen geschreven
Cal Poly, Team S22-G6, Maness Spring 2018 Lid van Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 505
