Ga door naar hoofdinhoud
Samsung Galaxy Note Display Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note Display Assembly Replacement, Stylus: stap 1, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement, Stylus: stap 1, afbeelding 2 van 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Display Assembly Replacement, Rear Case: stap 2, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement, Rear Case: stap 2, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Display Assembly Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 3, afbeelding 2 van 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Display Assembly Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement, Battery: stap 4, afbeelding 2 van 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: stap 5, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: stap 5, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: stap 5, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Display Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Display Assembly Replacement, SIM Card: stap 7, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement, SIM Card: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Display Assembly Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 8, afbeelding 2 van 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Display Assembly Replacement, Midframe: stap 9, afbeelding 1 van 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Display Assembly Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 10, afbeelding 2 van 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Display Assembly Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 11, afbeelding 3 van 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Display Assembly Replacement: stap 12, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 12, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 12, afbeelding 3 van 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Display Assembly Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 13, afbeelding 2 van 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Display Assembly Replacement, Motherboard Assembly: stap 14, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement, Motherboard Assembly: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Display Assembly Replacement: stap 15, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 15, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 15, afbeelding 3 van 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Display Assembly Replacement: stap 16, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 16, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 16, afbeelding 3 van 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Display Assembly Replacement: stap 17, afbeelding 1 van 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Display Assembly Replacement: stap 18, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 18, afbeelding 2 van 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Display Assembly Replacement, Display Assembly: stap 19, afbeelding 1 van 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  20. Samsung Galaxy Note Display Assembly Replacement: stap 20, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 20, afbeelding 2 van 2
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  21. Samsung Galaxy Note Display Assembly Replacement: stap 21, afbeelding 1 van 1
    • Using tweezers, or your fingers, remove the front-facing camera assembly.
  22. Samsung Galaxy Note Display Assembly Replacement: stap 22, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 22, afbeelding 2 van 2
    • Use the tip of a spudger to pry the headphone jack/earpiece speaker assembly out of its recess in the display assembly.
  23. Samsung Galaxy Note Display Assembly Replacement: stap 23, afbeelding 1 van 1
    • Use tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly.
  24. Samsung Galaxy Note Display Assembly Replacement: stap 24, afbeelding 1 van 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  25. Samsung Galaxy Note Display Assembly Replacement: stap 25, afbeelding 1 van 1
    • Lift the speaker enclosure from the display assembly.
  26. Samsung Galaxy Note Display Assembly Replacement: stap 26, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 26, afbeelding 2 van 2
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
  27. Samsung Galaxy Note Display Assembly Replacement: stap 27, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 27, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 27, afbeelding 3 van 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
  28. Samsung Galaxy Note Display Assembly Replacement: stap 28, afbeelding 1 van 1
    • Remove the USB board.
  29. Samsung Galaxy Note Display Assembly Replacement: stap 29, afbeelding 1 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 29, afbeelding 2 van 3 Samsung Galaxy Note Display Assembly Replacement: stap 29, afbeelding 3 van 3
    • Insert the tip of a spudger under the vibrator connector cable near the contacts then slide toward the vibrator itself.
  30. Samsung Galaxy Note Display Assembly Replacement: stap 30, afbeelding 1 van 2 Samsung Galaxy Note Display Assembly Replacement: stap 30, afbeelding 2 van 2
    • Insert the flat end of a spudger under the vibrator connector cable, and pry it up from the adhesive.
  31. Samsung Galaxy Note Display Assembly Replacement: stap 31, afbeelding 1 van 1
    • Remove the vibrator from the display assembly.
Conclusie
42 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.738 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.767 handleidingen geschreven
6 opmerkingen
étape 31 ensuite ??
Fabrice - Antwoord
i have a galaxy not and its display is badly broken,at the top of the phone(front side),the display is broken so badly that i am able to a little circuit i.e. a brown color wire which is connected to the display.
so my ques. is that can the phone work after repairing or it has gone?
Abhishek Kumbhar - Antwoord
Hello Abhishek Kumbhar, if the motherboard is not damaged it's all fine. All other parts are replaceable
Georg Fischer - Antwoord
excellent photos
of samsung 717
murali maroju - Antwoord
i am trying to get my phone to charge but its not and i have it pluged in and it doesnt want to charge
Anthany Kleven - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 44,131
