Inleiding
Use this guide to replace the front panel display assembly in your Samsung Galaxy Note.
Wat je nodig hebt
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to carefully disconnect the display cable connector.
Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
42 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Fantastic !!
i have a galaxy not and its display is badly broken,at the top of the phone(front side),the display is broken so badly that i am able to a little circuit i.e. a brown color wire which is connected to the display.
so my ques. is that can the phone work after repairing or it has gone?
Hello Abhishek Kumbhar, if the motherboard is not damaged it's all fine. All other parts are replaceable
excellent photos
of samsung 717
