Ga door naar hoofdinhoud
Samsung Galaxy Note 5 Back Cover Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: stap 1, afbeelding 1 van 1
    • Heat the back cover to melt the strong adhesive sticker underneath.
  2. Samsung Galaxy Note 5 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
  3. Samsung Galaxy Note 5 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • If you do it hardly, you need much more heat especially the edged side.
    • Slipping a playing card through the gap is a good way to loosen up the adhesive.
  4. Samsung Galaxy Note 5 Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover. The white stripe is the sticker.
Conclusie
45 andere personen hebben deze handleiding voltooid.
Sophia
43.810 Reputatie
62 handleidingen geschreven
9 opmerkingen
What about putting the one back on?
rcf917 - Antwoord
will it go back on and stay on without new adhesive?
dfasdfjiun - Antwoord
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
Witrigs - Antwoord
How do I remove the sticky part
Marcelino Lopez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 26
Altijd: 108,750
