Ga door naar hoofdinhoud
Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement
Wat je nodig hebt
Video overzicht
Samsung Galaxy Note 4 Rear-facing Camera Lens Replacement
  1. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
    Back is not flexible and will shatter
    bobby moran - Antwoord
  2. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: stap 2, afbeelding 1 van 3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: stap 2, afbeelding 2 van 3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: stap 2, afbeelding 3 van 3
    • Use a pair of tweezers to pry off the rear-facing camera ring.
    • You may need to use the tweezers to run along the sides of the camera ring to loosen it.
  3. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: stap 3, afbeelding 2 van 2
    • Use a pair of tweezers to peel off the camera ring adhesive.
  4. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: stap 4, afbeelding 3 van 3
    • Gently slide one tip of a pair of tweezers underneath the rear-facing camera lens.
    • Pry upwards with the tweezers and remove the camera lens.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Sophia
43.810 Reputatie
62 handleidingen geschreven
2 opmerkingen
Iam gonna order this now. Thanks for the tip. How much should I expect to pay for new lens. ????
Tommy Holmes - Antwoord
aliexpress or ebay from china ~$1
altomic -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 35,555
